I did a little research and found that the tail lite sockets will fit the front. It was so easy just take out the front turn signal sockets and replace with the tail lite socket and wire them in. I cut the origanal ends off and soldered them into the brake lite and ground wires making them so they plug in like stock. for the running lite I took the existing wire that is there above the headlamp for the european busa's that have running lamps and wired it in. simple and I think very cool. Also you'll notice the headlamp is off do to I wired in a toggle switch in order to turn on and off..A couple pics to follow..
