Y2K81 Registered Oct 6, 2016 #1 I'm 135lbs.. springs installed are for a 240lb rider. I'd like to get whatever is considered a step up or 2 from stock as I'm only 135lbs. Bike is a daily rider... Well once I get the motor back.
13013 Registered Oct 6, 2016 #2 I'm fairly certain stock rate is what you want with your weight. Someone will chime in with more knowledge than me.
Y2K81 Registered Oct 6, 2016 #3 What about 2 up. Cause I do alot of that. Need to take that into consideration as well.
M mjl3truck Registered Oct 6, 2016 #4 Go to Race Tech's web site and enter in your info and it'll tell you your spring rate needed.
