I am hearing/feeling a noise/vibration coming from what seems like the front sprocket while going down the road. When I pull the clutch in it stops.
I have taken the cover off the front sprocket and everything seems tight. Someone I work with suggested it could be in the clutch side that a bolt has loosened up. I plan to check that tomorrow but I have never worked on bikes but am very mechanically inclined.
If any of you could share some of that wisdom and knowledge I would be greatly appreciated. Anything I should be looking for since this is all new to me?
It is a:
2006
roughly 15,000 miles
all stock excecpt for exhaust
It is used mostly as a daily commuter 50 miles per day with some light sprited riding on the weekends.
Thank you.
It is a:
2006
Thank you.
