Front Sprocket socket
MoNoXiDe
Could anyone tell me what size socket I need to take the front sprocket off? Is it the same socket size for the rear? Gen 2 busa
Also if someone could post the code for the speedohealer, 1 down in front same in rear.
36mm
:beerchug:
The gen II rear axle nut size is 36mm as well, so it may be a good idea to invest in a 36mm for about $8 so you can get proper torque.
Not sure, I went with a SpeedoDRD instead. If you go to Speedohealer website though, they probably have a GPS calculated change and a sprocket/manufacturer change indicator.
Here is the rear one
