front sprocket
fast1200gp
What size is the nut holding front sprocket on? and whats the torque- gonna try a 16 tooth front,,and the little sensor i guess the speed sensor the bolt was loose,,,common??
thanks guys.
Can't recall for sure, but I think the front sprocket is a 32mm. 105 lb-ft on the torque. Use some BLUE thread lock on the threads.
Does it have a lock washer
There is a washer between the nut and the sprocket. Might have to bend it to get nut off.
