Front Stand?
Ham
Hi purchased a set of stands unfortunately when lifted on the front stand to remove the front wheel for service i can not slide the front axle out because it hits the stand. (Fork stand type)
see yellow arrows the axle hit that part and will not slide out on both sides.
Not my video but does the same thing. start watching at 6:47
Simple solution is to put a wadded rag on the stand before you lift the wheel. Axle should clear the stand. Careful not to tip bike over.
These type of stands scare the crap out of me, a stem stand makes me feel better. Did you get the axle out?
I use a Pitbull stand that has two pins that go up under the bottom of the fork. I was able to get my front wheel out no problem. I'm a big fan of the Pitbull stands; really nice quality.
