Ok I'm removing the front wheel/tire on the bike for the first time.
Loosened pinch bolts(then pryed apart slightly with a screwdriver) removed caliper. I can get the spacer on the left side of the bike to come out about 1/4 inch by prying carefully with screwdriver/various implements of destruction. The axle also moved left about the same distance now it seems like everything is tight. Am I missing something or do I just need to get a bigger hammer/more force? What tecnique should I use beating on axel from right side with large socket and hammer or pry spacer from left side???
<!--EDIT|TheDude27
Reason for Edit: None given...|1120057260 -->
<!--EDIT|TheDude27
