front wheel removal tool
AES
can anyone tell me where i can find that huge ALAN HEAD wrench to remove the front wheel. dealership wanted $80.00
go to Home depot or Lowes and get a bolt with that size head and 2 nuts and a lock washer and that will work. Thats how my broke a** does it.
Use a spark plug socket, I think it's the one that fits the 13/16th spark plug, or you could get an all thread rod connector from a hardware store, I don't remember the size...
(georgiabusa_05 @ Mar. 04 2007,19:41) go to Home depot or Lowes and get a bolt with that size head and 2 nuts and a lock washer and that will work. Thats how my broke a** does it.
Yup. I *think* it's an 11/16" bolt that you need. The head will fit right into the axle.
I got a couple of nuts and welded them to the bolt (no comments from the gallery!).
I think the total cost was about $2 bux!
(omslaw @ Mar. 04 2007,17:52)
Thats what I use too, works like a champ!
I bought the "real thing" on ebay for around $24.00. I couldn't find the correct size bolts at my home Depot.
A 5/8 bolt has the proper size head on it to fit into the front axle. The head measures out to be 15/16 acorss. I went to Lowe's and bought a 2" 5/8 bolt and nut for $1.30 and had friend weld the nut onto the bolt. Best investment and money saver ever.
If you do a search there was a thread that covered this before. But here is a pic on what I use.
(kml @ Mar. 04 2007,09:05) coupling, Home depot, under a buck.. 15/16, I think...
there is the best cheapest answer!! I used a couple nuts and a bolt
for $80 id rather drive to the stealership n "borrow" one of theirs...too itd never make it back
didnt know they cost THAT much
good thing my stealership likes me.
