sailortrash
Where do i buy one?
how expensive is expensive. Your set up is basically what i am shooting for. I need the bags as well. I want at least 5 gal of fuel.Mine is custom-made... horrendously expensive.
However, I went this route because I had (at the time) specific requirements: I wanted the cell to reside on my FJR1300's pillion seat, yet it had to also fit between the two "legs" of the Givi rack.
The only way that's going to happen... is with spendy custom work.
However, itr was worth it in the end... 4.9-gallon aux cell, plus the stock 6.6 gallon, gives me 11.5 gallons total of onboard fuel, which is the maximum allowable under Iron Butt Association rules for competitive Endurance Riding.The cell for the FJR came out pretty sweet....
Here I am laying out the floor of the cell using cardboard mock-ups:
Finished cell before the tankbag was sewn for it. Note red lever that opens fuel valve to start the fuel flow by gravity:
Right side - vent line feeds through the inner fender and exits aft of rear tire. You can also see the very important anti-static ground wire (wrapped around top of vent line) prior to connecting it to the frame of the bike.
Finished cell, viewed from the front of the bike:
The cavern created by the enclosure hold tools, tire repair kit and electric air pump to repair flats on the side of the road:
Linda Tanner custom tankbag for this aux cell installed, Givi topbox installed, bike was ready for some serious LD business:
And this cell now resides on my K8:
nice. No poly does not bother me at all. How much trouble is the install? What extras are needed?
