Y.J
Hello everyone,
I want to share this information and notice...
I had problem about Fuel Guage function , problem is almost FULL always...
My Busa is 2016 Model and just 7000km running.
So I fixed already for this problem by replace to new sender unit.
And then try to find problem from broken sender unit.
First of all, Please see below picture...
Problem is Metal(I guess Silver) contact short by spread metal print.
In my case,I got fuel guage reading problem from this issue. (Lower only 72 ohm...)
But I saw many like this problem (Fuel guage stack full or no-lit/very late Fuel empty lamp or non linearity) from BUSA ORG.
I guessed those problem from same this issue..
This problem bring complicated problem, I guess.
Because come problem progress is slow.
Slight case, just can not take fuel low level but can not lit empty also.
So I recomend that checking once for everyone.
I wrote that how to check with out disassembly:
1: Running BUSA until almost fuel empty.(less than 1 or 2 litter left)
2: Tank lift.(Move to lowest position flort)
3: Disconnect the fuel pump coupler.
4: Check to resistance by tank side coupler.(B/W-R/B)
5: If resistance 130-133 ohm when Okay.
If less than 130 ohm... May be need to sender check.
How to repair for this problem:
I tried repair and got good result already by bellow.
1: Remove Fuel pump.
2: Remove Sender unit and check same problem or not.
3: If same problem when try below.
4: Brush to problem point by cotton swab with compound.(Carefully!!)
5: Remove to compound by alcohol.(Carefully again!!)
6: Check ohm again.(Lowest position 130-133 ohm, Highest position 11-13 ohm)
7: Reassemble.
I hope that helping for you from this share.
Thanks!!
7: Reassemble.
Thanks!!
