i'm trying to remove #3 cilinder fuel injector, i'm lookng at the manual it look pretty easy but they looked like i have to remove the whole bar holding all injectors to get it out. help needed thanks
Yes, it's really easy. I pulled all four injectors in 5-10 minutes. They are out getting cleaned and serviced now. In fact, should have them back sometime today
I did mine while I had the valve cover off for the valve inspection....you GONNA LIKEY !!! Tuning the throttles was a breeze and now it runs like a Hayabusa's supposed to..... 1kg on the phillip's-head-screws, and a touch of blue loctite. Get the new o-rings wet with fresh oil and slide them in.....
