I've just completed installation on an RCC stage 1 Turbo kit. I've started the bike but haven't ridden it yet or had it tuned. The PCIII has the RCC map in it.
I added a DynoTune electronic fuel pressure gauge to the bike today and the fuel pressure is fluctuating a bit.
At idle, the pressure will read 43.5 and as the gauge updates every second or so the pressure will hover around 43 give or take 0.5. But every so often, say around 4-6 updates, it will drop down into the 10-25 range for a single update before going back to around 43.
I held the throttle at 2000 and then 3000 rpm and saw about the same behavior, except that values in the 17-25 range happen a little more frequently. Sometimes the pressure holds steady at 43ish for 15-20 seconds before jumping around a bit.
I don't see any kinked fuel lines and the bike is idling ok.
If I turn on the ignition and watch the gauge during the few seconds the fuel pump runs, the pressure goes up to 36 and then drops way down after the pump stops.
This is my first turbo and I'm not sure what is typical for fuel pressure. Is this kind of fluctuation normal?
2005, stock injectors, basically all stock other than the RCC kit.
