Neophyte
I need some advice please. Since yesterday the fuel pump on my 2006 Gen1 is not running and not priming at all. Fuel pump runs when applying power directly to it. It seems the fuel pump relay is not being triggered.
After checking the wiring diagrams and from what I get from testing I suspect it to be the side-stand switch or maybe even the side stand relay.
The side-stand switch has a diode according to the diagram, confirming why I could check continuity only in one way. The "right" way gives me fairly high resistance when I check for continuity. Is that right?
And how do I test the side-stand relay?
I also don't get a C41 error code in case you are wondering.
