The F1 light blinks??
The Fuel pump will not come on??
The diagnostics reads C-23 which is a tip switch fault or wiring problem?? I swapped tip switches still doesn't work?
I have changed out the body including the tank....installed a switchable TRE which wires into the the orange/white fuel pump relay wire.....
THE BUSA HAS 0 MILES!!!!!
Any ideas before I take the whole ass end off to remove the TRE and see if that is what it is??
If the tank was completely try will this cause something like this? I didn't have much gas laying around?
THANKS FOR YOUR HELP IN ADVANCE!!
Best Regards, Josh
816-370-3334
Best Regards, Josh
816-370-3334
