Fuel pump?
Midnight turbo
What do you guys use to connect your inline fuel pumps to the tank and fuel rail? Will barb fittings and hose clamps work?, will they take the pressure and not leak? Want to get one of the T-rex pumps but it comes with barb fittings. Just wondering if they will hold the pressure. Any tips or pics of what yall used would be very helpful. I know barb fittings will work on the intake side between the pump and tank, more interested in the outlet between the pump and fuel rail. Has anyone used one of vortech's universal fuel pumps? It only puts out 8 less gallons per hour than the t-rex, but it does it at 70psi just like the t-rex, and only cost $89.00. What do you think Ninja?
Fuel pump will work fine with the barbs but use hose clamps also. You do not need a T-rex unless you are pushing 230hp or more, other Vortec and Bosch etc. will work great.
