fuel pump
ctbusa
I installed a inline fuel pump with rising rate reg and splised the wires for the power pumps not running and fi light blinks can somebody help me please
Posted via Mobile Device
hey how r u? make sure the wire's are connected write. when u turn the key fuel pump doesnt kick on? make sure it has a good connection.
ok try this, connect the old pump, see if it fires up. u dont need to put everything back together just the wires of the old pump. to see if the connection is good if that works somethin may be wrong with the inline pump.
check your fuse., std 10 amp will not run some pumps for long , 15 is needed
and bridge the dealer plug to see what codes ,may make it easier too see whats wrong
I put the pump straight on the battery and it runs but if I conect it on to the wires at the plug nothing happen does the fuel gage sender unit need to be conected
Checked I'm on the right wires but servos doesn't wanna run changed the fuse as well
Kill switch on right handle bar not on, in gear with side stand switch on, the fact the FI light is on says you have something on the bike not turning on the fuel pump relay. Something as simple as your kill switch,
Richard
Do you know why your FI light is on???? Once you figure that out you will have solved your problem.
Richard
Ok got the pump to run but fi stil flashing driving me crazy also doesn't wanna start
Its alive again thanks for al the help guys sitting in south africa I'm glad that you guys can help me (its also your fault that I started this whole thing) but thanks
