Fuel pump
Zorro666
08 busa,43+k everything original ,never had any problem except 2 weeks ago my fuel pump start to making some noise but 5-10 minutes after i start riding.No loss of power or performance. I replaced the original pump/motor with the aftermarket one and i replaced the strainer/filter too.Same things happened again.Please help!
What kind of noise? Only when the pump primes? Or is it constant?
Quantum Intank EFI Fuel Pump For Suzuki Hayabusa (GSX1300R) 2008-2012, Replaces 15100-15H00
I'm thinking if you had the whining noise then changed the pump and still have the whining noise, it's not the pump...
Try to take a video if possible...trying to track down a noise without being there in person to hear it is nearly impossible IMO.
When it starts to whine, pull over and to be certain it is actually the fuel pump making the noise take a cardboard tube (toilet paper roll or paper towel roll) and put it on your ear, then put it up to the lower left side of the fuel tank.
You will soon hear the pump and verify whether that’s the whining noise or not.
Give it a try, it’s the old stethoscope method for tracking down noises.
Not my 99, Ist gear has no whine at all :poke:
If it’s still noisey when stationary and motor running, it ain’t the transmission!
Op has an '08, mine has a definite whine in 1st gear and I'm told it isn't a unique whine to just my bike.
Yep, if it is making noise when stationary, it isn't the tranny....even us backyard mechanics know that much :super:
My mate had a 2002 Busa, he said the guy he bought it from told him 1st gear whines because it has a straight cut racing gear installed. . . I said nothing, let him have his little dream, he still believes it to this day lol.
Mine whines and I asked the previous owner and he said it always did. I even asked the question on here and was told it is normal...Beats me...I sort of like it...
Did you replace the fuel filter also? Your pump was probably fine, filter clogged. Search for fuel filter mod on this forum, the oem filter is very expensive, you can do the mod for around 20.00
