rotts4u i would consider if problem ever happened to my bike.I like your set up very clean looking.
wondering if you will have a problem
if you get low on fuel where your low
fuel light comes on how is that last gallon of fuel going to work its way
up hill to your fuel pump,since the pump is gravity feed. the fuel
pump & lines should be lower than bottom
of tank, just in case you need that last gallon of gas. have you had that problem or you dont let fuel get that low.
