I have an 02 HAYABUSA with an IN TANK FUEL pump.
anything over 9k, and my bike falls on its face from fuel starvation.
Here is what I know so far:
- ive installed a fuel pressure guage
- the fuel pressure guage shows 42psi steady from idle to 9k
- the bike falls on its face at 9-10k
- the fuel pressure guage shows 24 psi above 9k.
- i cleaned out a bunch of poop from the big filter in the FUEL PUMP designated number 3 on the diagram below.
- i ran the bike for a day, and then rechecked the filter again, and it was perfect.
- i replaced the stock fuel injection lines with steel braided lines and ensured no crimping.
- tried running the bike with no gas cap, to ensure no vaccum.
- changed the fuel pump with a new one, still getting low fuel pressure above 8k (20psi!)
- changed all four injectors
now im looking to go thru every filter in the fuel system! so far, i have located and cleaned the filter located at POINT 3 in this diagram.
CLICK HERE FOR DIAGRAM OF FUEL PUMP ASSEMBLY
WHAT IS ITEM 2 IN THE DIAGRAM?
isnt this the fuel regulator?
if not, where is it?
isnt there supposed to be a filter between the fuel regulator and the pump?
WHERE ELSE ARE FUEL RELATED FILTERS LOCATED ON MY BIKE???! there must be more than one, and its the clog i hope!
please help me if you know where any other filters that could be causing low fuel pressure may exist.
<!--EDIT|NICKSLICK
Reason for Edit: None given...|1069897943 -->
<!--EDIT|NICKSLICK
