Reading Suzuki's web site it looks like the Cal bike has a smaller gas tank (capacity wise at least)
Specs
Engine: 1299cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
Bore Stroke: 81.0 x 63.0mm
Compression Ratio: 11.0:1
Fuel System: Keihin/Denso Fuel Injection
Lubrication: Wet sump
Ignition: Digital/Transistorized
Transmission: 6-speed, constant mesh
Final Drive: #530 chain
Overall Length: 2140mm (84.3 in.)
Overall Width: 740mm (29.1 in.)
Overall Height: 1155mm (45.5 in.)
Seat Height: 805mm (31.7 in.)
Ground Clearance: 120mm (4.7 in.)
Wheelbase: 1485mm (58.5 in.)
Dry Weight: 217kg (478 lbs.) 218kg (480 lbs.) CA. model
Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, 14-way adjustable rebound damping and 13-way adjustable compression damping
Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, 22-way adjustable compression & rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 190/50-ZR-17
<span style='color:red'>Fuel Tank Capacity: 21 liter (5.5 gal.) 19.0 liter (5.0 gal.) CA. model</span>
Color: Black, Red, Blue
Specifications and features are subject to change
