Full Bore Tires ?
not till I know who is making them... (they are not)
who is doing the compounding?
who is testing them?
Where are they being tested..?
you can have tires made and branded but you better have your ducks in a row for how the rubber is compounded...
could be perfectly good tire or perfectly lousy... :)
Full bore tires are made out of the Continental factory for about two years now. They are close to the oem slipstone tires.
Fullbore. M1 = shinko 009. They last exactly 2500 miles. Over 2.5k, they lose grips dramatically. But I paid less than 100 for each. Can't beat that! I'm sure someone else will chime in to correct me.
Posted via Mobile Device
You are corrected.
Never heard of them myself untill just recently,A buddie had a set on his GSXR1000 they were decent..bike had a arm and hooked!!
Rode with a guy on a R1 this weekend around Robbinsville. He was running the full bores. He was tearing the dragon up. He said he had no problem with the grip.
Ive ran m-1 full bores, they really good for drag, they have kind of a flatter profile, and get really sticky...alot of drag racers here use them, as far as other models for the track, have used them also, M-3s take time to heat up but once they do, they work good....they DONT however last very long
I don't like the way it is written. The statment, "With it's near slick design, this DOT approved tire will soon have a cult following at track days and become the tire of choice for drag racing. " It kind of puts me off. I have learned to listen to the little voice that says something might be wrong.
Never tried them but I don't like the tread pattern doesn't look like it will move to much water out of the way for my rides in the rainstorms. Give a review if you give them a try
never tried them before. Since they are the about the same price, i'll probably stay away...a bike has only wheels, better not take chances
