NICE N EASY
I wanted to get more visibility by turning my turn signals into running lights. Originally, changed out the socket and went with a dual filament bulb, essentially, got half power running lights, better than nothing. However, installed Priority Lites coupler which are used to turn your rear turn signals into running lights. Wired it into the front turn signals wiring harness, tapped into the low beam, good ground to the frame and volia, now I have full power front runing lights. Very pleased and they match the intensity of my Priority Litres Plus which I installed for the rear turn signals. The only down side is that you need to keep the battery charged up during down times, otherwise, very visible and conspicuous. Rafael
