Full System Mod?
flyboy
If I go with a full system what else do I need? Sounds like I need to add other stuff that I have no clue about. I planned on only adding slip-ons, but for the money they want for slip-ons I can get full system which gives me a little more horse power and lose some weight at the same time.
have a custom mapping on a 2001 busa with full dual devil high mount with k n filter and the busa doesnt seem to run fight. It wants to cut off during acceleration.
you'll want a power commander!!!
this way you can change the maps for whatever other motor mods you perform. ie: filter, cams, ect.
PC3R and a BDE Gen 3, Akrapovich, HMF, or Muzzy for dollar value would be my choice.
May as well lose the pair, and throw in a BMC filter at the same time
please help, need a mapp for 01 busa with a Devils full dual high mount system with k and n filter, and pc2. Any busa rider here in Fort Wayne ,IN?
I BOUGHT THE MICRON FULL RACE SYSTEM AND A K&N AIR FILTER.
YOU SHOULD USE THE POWER COMMANDER IT IS SEPERATE FROM YOUR EXSITING EFI CONTROL IF YOU EVER WANT TO REMOVE IT YOUR STOCK MAP SETTINGS REMAIN UNCHANGED.
