Pat Dietrich
The only time i will ever "plug" a product is if I think it's worth doing. I don't know Brock Davidson so I'm not out to help his buisness BUT....
Last year I was running the late model stock cusion that suzuki puts in the busa, and it worked great, no problems. A friend of mine( 469boy) had a BDE Cusion laying around and offered it to me to try out. So I did. Lets go back to racing with the stock cusion for a second. My normal 60s were 1.51-1.55 with an absolute best of 1.49 maybe twice. This year first time to the track with the BDE cusion and the first run was 1.51 then a 1.49 followed by 3 in a row 1.48. Then we got rained out. Second time to the track was this last Fri and started with a couple 1.51 (testing track) and ended with a best of 1.463 also had a 1.47. The track was very touchy on where you lined up also. I wish it would have been nicely sprayed to see if i would run consistantly in the 1.46-1.47 range but when I tried to run hard out of the hole towards the end of the night i spun bad. I honestly believe it works better than the stock cusion. Cost alot more, but if your after every tenth you can get because of the latest Turbo addiction thats sweeping the country ( thanks to motorhead )
then i would probably opt for one of these over the stocker.
<!--EDIT|CANDYBUSA
Reason for Edit: None given...|1090776205 -->
<!--EDIT|CANDYBUSA
