Gasoline vs. printer Ink
gurrera
All these examples do NOT imply that gasoline is cheap; it just illustrates how outrageous some prices are....
> > You will be really shocked by the last one!
> > (At least, I was...)
> >> > Compared with Gasoline......
> > > Think a gallon of gas is expensive?
> > This makes one think, and also puts things in perspective.
> > Diet Snapple 16 oz $1.29 ... $10.32 per gallon
> > Lipton Ice Tea 16 oz $1.19 ..........$9.52 per gallon
> > Gatorade 20 oz $1.59 ..... $10.17 per gallon
> > Ocean Spray 16 oz $1.25 ......... $10.00 per gallon
> > Brake Fluid 12 oz $3.15 ...... $33.60 per gallon
> > Vick's Nyquil 6 oz $8.35 ... $178.13 per gallon
> > Pepto Bismol 4 oz $3.85 .. $123.20 per gallon
> > Whiteout 7 oz $1.39 ....... . $25.42 per gallon
> > Scope 1.5 oz $0.99 .....$84.48 per gallon
> > And this is the REAL KICKER...
> > Evian water 9 oz $1.49..$21.19 per gallon! $21.19 for WATER and the buyers don't even know the source
> > (Evian spelled backwards is Naive.)
> > Ever wonder why printers are so cheap?
> > So they have you hooked for the ink.
> > Someone calculated the cost of the ink at...............
> > (you won't believe it....but it is true........)
> > $5,200 a gal. (five thousand two hundred dollars)
> > So, the next time you're at the pump,be glad your car doesn't run on water, Scope, or Whiteout, Pepto Bismol, Nyquil or God forbid, Printer Ink!
> > Just a little humor to help ease the pain of your next trip to the pump...
Gurrera
