Ratlin’busa
Ok, so I bought a 12’Oclock labs speedo healer, and then an Ideas Electonics gear indicator. I’d have a 16/42 sprocket setup and I’d like the gear indicator. It looks like I can install them inline together.
So I have 2 questions:
1- do I install the Gear indicator or the speedo healer in the line first(starting at the speed sensor) or does it matter?
2- for the green wire- I need to tie in to the Crank position sensor line. If I’m understanding it correctly- I need to follow the Ckp wire back to the connection and tie onto the green wire on the ecu side of that connection- correct?
Thanks.
Thanks.
