Could you tel me more about this gear indicator please?NJ.From what I understand the Acumen can lag a bit after the gear change as it calculates via the tachometer signal
I have an Indicator from EKS which also has a built in smart TRE, it also reads straight from the gear selector so there is no lag at all
And it' cheaper
around $100US delivered
me too... I am most interested in this one...Could you tel me more about this gear indicator please?NJ.From what I understand the Acumen can lag a bit after the gear change as it calculates via the tachometer signal
And it' cheaper
There was a thread about this earlier and as I understand it they are not available or are no longer made. That info could have changed as people looked into it but that is where it was at when I saaw the thread last.From what I understand the Acumen can lag a bit after the gear change as it calculates via the tachometer signal
And it' cheaper
I'm sending an email to the manufacturer. They don't seem to have prices on the site.From what I understand the Acumen can lag a bit after the gear change as it calculates via the tachometer signal
And it' cheaper
