I want to change my gear ratio. Either by changing the front sporcket, rear sprocket, or both. I've heard the hot setup is to change the front to a 16 tooth sprocket. Will that change significantly induce premature chain wear? My gear choices right now are 16 tooth front, stock rear, or go 16/42. I have an 03 Busa.
DBLX
DBLX
