outcast: didn't you have a friend that ran a 6.12 in the 1/8th at a 120mph? if he really did this, this is the guy you need to find out about gearing... as a DRAG RACER, i can tell you that there is alot of thing's that come in to play when your trying to find the right combination.like; your whieght,your track,your particular bike's hp output. and so'on.first you need to dyno your bike,find out where your cam's quit building hp.that's going to be your shift point on all gear shifts.if your a light person then on this bike you'll probaly try to set it up at the top of 4th gear.(for the 1/4 mile).set it so when your going through the traps right where your bike quits building power!since your around 200 plus.i'd do a 5th or 6th gear setup.remember what works for one guy might not work for the other. but this info i just gave you, should be very helpful in acomplishing your goals.also each time you make a hp mod,you'll probaly need to make a gear change.depending how much you changed. 3 hp is quite a differance at the track. if your going through the traps at the top of third,one down in the front will put you at the top of fourth.one up in the back will give you around 500 rpm.remember it's very important not to go past were your cam's quit making power! if it stops at 9,750rpm. then shift there!! there's no since going past that since it's not making any power up there.if you what to make power beond that,then you'll have to change your cam timing.which is another thing thats important for your whieght! i could keep going on,but i'll stop.... try some of this info & good luck.....FRANK
