I'm appreciative of any assistance you gurus here can provide.
My gas tank leaks. Originally, I thought it was the hoses had disintegrated but after replacing them the tank still leaks... a lot! I determined it's the gasket, part number 34820-24810 which is discontinued, at the bottom of the tank where the fuel level sending unit mounts.
Since the part number is discontinued, is there a fix? TIA
