As
@sixpack577 has already said, the fuel pump may well be the issue here, so delivery and pressure need to checked and verified before assuming it's injectors failing. . .
I've never heard of injectors cutting out when warmed up but Ok when cold, I mean,
it is possible, but unlikely, so first port of call is the fuel pump test.
Fuel pressure should be 3 bar (42psi) or thereabouts, and fuel delivery should be 458ml in 30 seconds.
Also, check the fuel pump relay is not faulty and going open circuit when warmed up.
When trying to track down the cause to any given fault on your bike, first break it down to looking at systems as a complete picture, understand how it works as a whole, and then test test test!
Also, a fault may be linked to an electrical driver or a mechanical action within the (fuel) system, one may cause the other so look at it in multi faceted way.
Just my thoughts, let us know how you go . . . Kiwi.
