05 with 62l and a pc3. I was riding home last weekend, and thought i smelled a little burning smell. When I shut it off, it wouldn't restart. I replaced the battery (it was actually deformed a little) The fuel pump relay was making a clicking sound, so I replaced that as well. Bike started fine after I put a new battery in, so I checked the rectifier, and it was overcharging. I replaced that, and things seemed to be ok. I put bike back together, and noticed I didn't have headlights. Both bulbs had burnt out, so I replaced both of those as well, along with a flasher relay. It had been started/shut off probably 20x today, with no issues. I went for a test ride, and it started fine. Headed out on the road, and it rode normally... Within about 60 seconds, it just died, and now won't restart.
So, NOW.. I have it in neutral, kill switch on, and when I turn the key on, the gauges go like normal, Oil light goes on/stays on like it should. Neutral light is on like it should, FI light goes on for a couple seconds, then shuts off. (I Thought it was supposed to stay on till I hit the starter, but I don't remember) Temp gauge goes to HOT, then cools back down. Couples seconds later, it goes back to HOT again. The fuel pump doesn't prime at all, and it won't even attempt to crank. (battery is charged) My odometer shows normally, and the clock shows CHECK.
As it sits now, I disconnected the PC3 and put it back how it originally was.
So, where do I start now? What are the usual, and easy things to check. I'm pretty good at mechanical stuff, but I absolutely hate electrical stuff, so you might have to walk me through any electrical type things.
Thanks for any tips/advice
