hey all still waiting for the map sensor to arrive so can't run the bike yet but the downtime has given some time to get some maintenance in after the winter....I hate road salt.......I'm sure there's a better alternative than salt available...
I think I'm going have a set of winter components to swap out with the good stuff in the waiting when the weather improves,...
Ok, back to the fuel pump issue.....yes....
was your bike cutting out before you removed the fuel pump?
Yes it was, it displayed some odd stuttering and misfiring when the fuel level got about a quarter tank, I once ran the bike until the fuel light came on and boy did the bike misbehave. I was on my way home and the misfiring started, I really struggled to keep the bike running.
Eventually I pulled on the the side of the road, and disconnected the PCII as I though this may have been going bad, anyway the bike restarted and ran fine for a few minutes then started to run worse than ever, in my attempted to keep the bike running I grabbed a full handful of throttle, the engine fired and I ended up in a huge power slide at about 60mph and accelerating on a busy, wet motorway.....I gotta say this was a change of underwear moment.......
So I got to a fuel station, brimmed the the tank and the bike ran fine....confused? damn confused...I put this down to crap in the fuel tank, so I stripped the pump out, cleaned the filters, washed the tank and fuel strainer out but didn't find, imho, enough residue or particulate to affect the running as it did...
So the pump screen was dirty on the lower half, the fuel pressure regulator screen was clear, the fuel filter was a little slimy but not as bad as I've seen in similar posts on Gen 2's, the injector screen were clear and no dirt in the injector rail as you would expect if the filter were doing their job.
My theory so far, is that when the fuel level get low, the pump is moving so much, it's possibly drawing in air with the fuel so cavitation is possible.
When I run the bike low in a straight line it's not so bad, in the twisties it's really bad. I guess in future the best option to to keep it above half full, easier said then does on long runs though...
