Gen 1 GiPro S02 to Gen 2 as speed elimater
ctk0104
Banned
Hi guy, i am TK from Singapore. Today I have fix my gen 1 gipro into my gen 2 and its work perfectly but there is one bad point about gipro to gen 2.
The bad point is when u fix the gipro into gen 2 as elimater, when u on yr ignition u will see yr stock gear indicator as N, when u go down on 1st gear and if u set yr elimater at 5th gear u will see 5th gear on yr stock indicator and gipro will show 1st gear.
The result will be as below when u set elimater @ 5th gear-
1st gear- Stock (blink to 1 then blink to 5) - GiPro (1st)
2nd gear- Stock (blink to 2 then blink to 5) - GiPro (2nd)
3nd gear- Stock (blink to 3 then blink to 5) - GiPro (3rd)
4nd gear- Stock (blink to 4 then blink to 5) - GiPro (4th)
5nd gear- Stock (blink to 5 then blink to 5) - GiPro (5th)
6nd gear- Stock (blink to 6 then blink to 5) - GiPro (6th)
If you wan both indicator to be same gear nos you can set it at - ...
Not sure if anyone posted this topic b4, any feedback pls let me know, thanks.
If you read further it shows that the Gi-Pro reacts faster, so I don't see a problem. We have one on our project Gen II.
hey tk iam from singapore too meet up soon
