I did a search and didnt find an answer... I replaced my tire and no issues removing front tire.
When I went to put it back on I got out my torque wrench and was sinching up the pinch bolts to 16.5 ft/lbs
As i reached 15 ft/lbs the bolt started twirling in the pinch bolt hole. WTF stripped inside.
I looked and it goes all the way through. My idea was to get a longer bolt and put a nut on the end to hold in place and tighten to the specified Torque number.
The challenge has been finding an 8mm bolt long enough and with threads all the way. I figure about a 2 1/2 inch 8mm should do it with a nylock nut
any thoughts??
What exactly do these pinch bolts do once the Axel is tightened and can I get away with a stripped one ??
any thoughts??
