Brock371
So don't get all crazy on me. This is my first Hayabusa and I have a few questions about it.
1- I was playing around with it the other day and noticed that I have cracked my sprocket cover that holds the clutch cyl. What would you guys recommend to fix this issue? If you have something that works to solve the breaking issues please let me know.
2- I noticed that when I pulled in the clutch all the way it made a grinding sound and the clutch basket side. could the push rod be hitting into something which caused the clutch cover to break?
3- I need to do the starter upgrade. Do I need to just replace the gear that makes contact with the starter shaft and replace the starter covers or is there more involved than that?
Guys I hope I'm not wasting your time. I'm new here and have a TON to learn. Any insight is appreciated.
Thank you
Thank you
