feket663
Hi! I have a gen1 Busa fom 2005 with approx 60 k miles. In the last year the oil consumption was little high, decrease from max to min approxx 100-120 miles. The bike had gen2 cylinder and Wiseco high compression, 81 mm pistons with relative new piston rings, and Kibblewhite vyton valve seals. The winter is coming, my mechanic made a piston change to original pistons and rings (the factory piston's mileage is 20 k miles, the rings runs only 5-6 k miles, coming from my bike), and original Suzuki valve seals. The cylinder was checked, no abrasion...
Note: The pistons and rings was nice, without traces of burns under the 3rd rings.
The motor is completed, no leakage, no problems, I ride in approxx 100 miles, without high revs and high throttle, without oil consumption, the level was middle between min and max.. After this period I started pulling throttle, but with brain, max. revs was 8500/min. And the result: after 100-120 miles the oil level was under minimum, need 500 ml to middle level.
My question to the experts: where is the problem? I'm using Motul 5100 10W-40 oil.
Sorry for my english...
