Gen 1 vs Gen 2 turbo long term build questions
1300cccappuccino
Hello
As the title suggests I have some questions about gen 1 vs gen 2 engines.
I have attached some photos from the internet to show how small these cappuccinos are.
Project details:
Engine is going in a Suzuki cappuccino time attack race car.
Project outline:
1400lbs target weight
550-650 Hp power goal
Id1700cc injectors
Maxxecu / haltech / aem what’s preferred?
Gtx2867 / g25-660 / PSR 5449A
Wossner pistons / rods
Full crank / block / head stud kit
Hardened shift shafts
Billet clutch basket
Hd clutch springs
Slave cylinder brace
EBay monster plenum intake manifold
Surge tank / aem 400 lph fuel pump
Dry sump
E98 to E50 for fuel possibly methenol
Please feel free to tear this list apart or add to it.
I am very familiar with the set up of stand alone Ecu’s I’m not really a tuner but I used to build cars for a living. It’s been a long time since I’ve needed a stand alone that can do things like traction control, by gear boost compensation, and rolling anti lag. What would you go with in the sub $2000 range?
Ok back to my original question. With this as the build plan… gen 1 or gen 2 as a staring platform? Where I am at gen 1 complete bikes are available in the $1800 range. Gen 2 stuff seems to be 2-3x more expensive.
Questions:
1. Does the gen 2 engine case / gear set / oil pump/ internal passages etc have any advantages over gen 1?
2. From what I understand gen 2 has weak valve springs. How are the rest of the components in the head on both gens?
3. The stroke is a bit different as well from what I gather. Is one crank stronger than the other?
4. gen 1 vs 2 clutch set ups. Does one have better aftermarket support than the other? Does any one sell a 10 plate basket? Is a lock up the only way to hold the sort of power I am trying to make?
5. does any one get rid of the individual throttles and use a single large throttle body at any point for making power?
Not 100% answering your questions but in the ball park….
Gen-2’s around here go for noticeably more money due to…
* They are obviously newer bikes.
* Better factory ECU’s.
* Stronger more reliable 2nd gears.
* Noticeably better brakes.
You also get a better choice having the longest production run.
Having said that, some of the fastest most powerful Busa’s I’ve seen have been based around Gen-1’s that have been built right and have money thrown at them.
Money really is the the great equalizer haha!
If I was not planning on going stand alone I think the gen 2 ecu would make it worth the extra money. I haven’t heard or read anything about the gear boxes yet! Are any of the other gen 2 gears stronger? Do the whole gear boxes have to be changed out or can you swap the primary and main shaft gear sets between clusters?
Those are cool little cars
U should do the trans whether u get a gen 1 or gen 2 so that’s negligible. Same with valve springs.
gen 2 will just get u 40 more cc due to the crank, better cams and 4 more injectors ….. u can put a gen 2 crank and cams into n a gen 1, and with a stand alone u can have as many injectors as u want.
Htp has built some single throttle body plenums.
Can you elaborate on what you mean when you say I should do the trans either way? There are a few companies that sell uprated gear boxes like NOVA for example.
Something to consider .. For high load/boost motors most builders recommend a Gen I cylinder .. The Gen II cylinders have webbing in them dedicated to reducing crankcase windage, which is prone to cracking under the loads imposed by high boost levels ..
Gen 2 block are fine for Unbored applications
I have used one for 5-8 years and it has been land speed racing and seen 28 PSI boost
Boring them is when they crack
In a minicar application either gen gearbox should be sent out for inspection/under cutting
If I was doing a serious money big horsepower build I’d be looking at better gears on either.
The Gen-1 has a bit of a reputation for weaker second gears that the later bikes don’t. Having owned several 1299’s and 1340’s that have had a hard life, the only failure I’ve had was a Gen-1 streetbike that had very little abuse and failed at half the mileage of my Gen-2’s. The fact that there are businesses advertising “Get your Gen-1 second gear fixed here” says it all.
For your application I wouldn’t rule out a Gen-1, it’s just something to upgrade and it’s probably a lot more related to stock(ish) road bikes than serious builds who’d be upgrading anyway.
Really if gen 2 stuff is 2x-3x, a gen 1 is a no brainer. All the replacement parts or work is going to cost the same regardless of gen, they’re basically the same parts.
Using a standalone u can even add 4 more injectors to a gen 1 if u wanted.
My turbo is a gen 1, spare engine is gen 1, about to build another gen 1. Bcuz it’s cheaper. Maybe one day I’ll get a gen 2 crank to put in a motor but my brain always says hey it’s a turbo, just add more boost and save $1800 lol
Gen 1 seemed to be the better option to me as well, I figured I should ask the community about it to ensure I’m not missing some viral component! Sometimes cheaper is better and sometimes the cheaper route ends up being a lot more work / money . Thanks for your response.
