With the Gen 2 airbox you can get a BMC race filter and change the Velocity Stacks. The GEN 2 flows so much better than the Gen 1 with a Large Airbox mod.
Gen 2 box flows better than Gen1 with large box mod? Did I read that right? ???
That is correct. The Gen 2 has a better and smoother transition from the lower chamber to the main chamber. Tested it on a flow bench awhile ago. I dont remember the exact flow numbers since I didnt write them down. Also the Gen 2's airbox is slightly larger than the Gen 1 so it has more of a reservior of air.
I think the new head probably moves a little more air for that stroker they gave us too.
Direct bolt on?I would guesstimate the Gen 2 Airbox is 10% to 12% larger. I installed a Gen 2 on a Gen 1 with no other mods and it picked signifcant horsepower.
Direct bolt on?
ThanksNo, see pics above for the Billet adapter plate
Must have been someone else I can't find anything on air box mod for Gen 2.
hi where do you get the billet adapter plate?
what is the purpose of it ?
thanks
