Mythos
Air Cleaner Element Inspection
The air cleaner element should be inspected for damage and cleanness every 4000 miles according to the Hayabusa service manual. The air cleaner element should be replaced if it is found in unacceptable condition. The maximum service life of an air cleaner element is 11000 miles or 36 months. It should be changed more often if the bike is run in a dusty environment.
Some after market air filters are meant to be cleaned and reused. The OEM air cleaner element should ONLY be reused without attempting to clean it or it should be discarded and replaced with a fresh one. Attempting to clean an OEM air cleaner element will probably result in damage to the filter or unnecessary engine wear caused by foreign particles entering the engine.
Tools:
phillips screwdriver
12mm socket
small vacuum cleaner
Prop the fuel tank. (step 1-2 https://www.hayabusa.org/forum/maintenance-do-yourself/168658-gen-2-how-remove-fuel-tank.html<<CLICK).
1. Remove the screws around the border of the air cleaner box using a phillips screwdriver.
Remove the screw in the center of the air cleaner box cover.
2. Remove the throttle cables bracket fastener with a 12mm (pretty sure it was a 12mm, maybe 10?) socket. Clear the throttle cables from the air cleaner box cover.
3. Remove the air cleaner box cover. Remove the air cleaner element and inspect it for cleanness and damage. Replace the air cleaner element if necessary.
My filter at 4.5 K. I reused it this time.
4. If any water is present in the air cleaner element box, remove the drain plug from the lower left corner. Avoid introducing any foreign matter into the air cleaner box or throttle body ducts. Use a small vacuum cleaner to remove any debris that is present in the air cleaner element compartment before replacing or reusing the OEM air cleaner element .
5. Install air cleaner box cover. Tighten all screws and the bolt that secures the throttle cables.
To save a tiny bit of weight, I used a zip tie in place of the throttle cable bracket. The hex head bolt that secures the air box cover to the frame must not be omitted, however. It seems to hold the entire air cleaner box in place.
Tools:
12mm socket
