Gen 2 Busa Won't Start
AceDaBusaBaby
My Busa wont start, I turn the key I hear the fuel pump, but when I press the ignition button I get nothing. The light goes off as if it want to start but nothing, no sound or anything. I've check the fuse box all fuses are good. I can push start it and it starts right up with no problem. Cant seem to find the issue.
Ok battery good... here is a list of current mods to try and help wit the brainstorming...Full Brock Exhaust, Power Commander 5, HID Lights, BMC Air Filter, and I have my heads Ported and Polished. Im going to check and see if the clutch lever and is properly engaging today. Still open to more input and ideas. Thanks in advance.
Ok battery good... Still open to more input and ideas. Thanks in advance.
most use the voltmeter ONLY as the sole basis to determine the health of a battery but a more reliable way is to get it LOAD-TESTED.
P.S. I am sure many here will take me as a broken record because this has become my standard answer for 98% of hard start/no-start issues that have been posted here. Best of luck.
