Hey guys! Does anyone have the flow rate data on the gen 2 injectors and is the flow rate the same for the upper as it is the lower???? Thanks in advance!!
Hey guys! Does anyone have the flow rate data on the gen 2 injectors and is the flow rate the same for the upper as it is the lower? Thanks in advance!!
Damm you smart guy. I read this one way, And then I was called buddy. Lb/Hr Tech, Static, 43psi. Call Bob Woods. He is close by you.
Kind of splitting hairs, but the spec is 270 CC/min @ 43 psi. I have RC recalibrate every race season, and they typically only measure 255 to 267 prior to clean / balance. It doesn't take much to throw them off.
BTW, that works out to about 37 HP per injector at an 80% duty cycle (maxed out). So you can only get 3x37 = 300 hp out of these injectors at 43 psi. This of course assumes you have a pump that can supply the fuel and a motor that can burn it. Thats why an adjustable regulator is handy.
