mike04busa
I would like to do this also.
Please keep us posted of any issues you encounter.
Isn't the rear wheel a straight up swap out ~ I believe the front has spacer issues to make it work . . .
I wonder if it would be easier to mount up an R1 front end under there with everything . . .
I dont believe thats Reds bike...maybe Im wrongRedbull ... You only running a single brake disc ??
I don't believe that's Reds bike . . .
Maybe I'm right ?
The rear rotor is a smaller diameter on the Busa wheel .
I believe SAE makes the correct one
that fits the Yamaha R1 wheel . . .
You may or may not need to use
a spacer in between the rear wheel
and inside of the swing arm . . .
On my gen 1 I used a thin washer
so that when I tightened the rear wheel
it did not get pulled into the rear wheel spacers .
I did not want to "squeeze" the swing arm
to close up the very small void there was .
I read that someone makes the spacers for the front rotors .
I need to call and find out .
I will weight the wheels
once everything is apart .
By the way @RedBull ,
that is a nice looking
Hayabusa man .
