Hey there,
Looking for some ideas on why my 08 Hayabusa won't start. I've had it for about a year and ride it a couple times a month. 16k miles on it, no modifications other than slip-ons and a filter.
Always have had an issue with the clutch lever relay switch being finicky when I start it, but it's never really been a problem because I just have to find the sweet spot(clutch level pull) and it cranks right up when I do.
Took it too a shop to test my battery, they said they could do a simple bypass on it that would fix it so I said go ahead. Turned out to be a paperclip jumper between the leads for the clutch relay switch. I didn't realize that when I drove off, but it did crank immediately without having to find the sweet spot. 5 mins later when I was being lazy and when to accelerate I heard this weird clicking sound and the FI light came on. I went right back to the shop and the mechanic came over and said "oh I was at lunch when you picked it up but I didn't mean for you to drive away with the paperclip jumper plugged in". He took it out and said to take it for a spin.
The FI light stayed off so I figure no harm was done. Put about 50 miles on it after that running errands around town. Next day I went to start it and it would crank but no start. Sounds like it fires one cylinder then immediately dies. Either stops sending fuel or spark after the first cylinder ignites.
Not sure if my trip to the shop is related because of the paperclip jumper OR it's something else......?
I tried a new Cam position sensor and new MAP sensor, neither worked.
Any other ideas? Or should I just try replacing the ECU?
