Thankyou, am I being thick here ? I've put linkage on the other way round, does the clutch need to be pulled in ?Yes but you have the linkage backwards, now it is reverse shift, or GP shift
Shouldn'tThankyou, am I being thick here ? I've put linkage on the other way round, does the clutch need to be pulled in ?
What @sixpack577 said. Move the output shaft back and forth to get things to align so it falls into gear (if it was put back together correctly).Have you moved the countershaft left/right to see if it will slip into gear then?
It will help to put the chain on and use the rear wheel to spin the output shaft in the quest for gear selection!Thankyou, am I being thick here ? I've put linkage on the other way round, does the clutch need to be pulled in ?
I'll give it a try, thankyou.It will help to put the chain on and use the rear wheel to spin the output shaft in the quest for gear selection!
Thankyou I'll give that a tryHave you moved the countershaft left/right to see if it will slip into gear then?
