Joshscott07
once the bolts/trim pieces shown are removed you may then pick up the small black plastic piece of the fairing enough see/remove the upper screw in the turn signal, then you can proceed to remove the bottom screw on the turn signal from under the front, yes the signal has two screws holding it in the dealer said it only had one lol, maybe a 10 minute job. they said it would take 1.5 hours to replace??? this is for the right side turn signal the left is the same process, i looked around for this info and could not find it, so hopefully this will help/save someone some time/money, thanks for viewing.
