Pull the two silver screws, then pop out the two inner push pins underneath the windscreen. You can then slip your finger in there and push the rubber retainer out. It helps to pull on it as you push it from underneath. After you get both sides out, the windscreen pulls straight back. When you put them back, start the screw in the rubber retainer, put some saliva on it and push it back in, tighten down the screw, reinstall the push pins and your done. Also, if you are putting an aftermarket screen back on it, be aware that it will fit extremely tight. Take your time so you dont break anything.
