Gen 3 power commander is out....
Ked0607
So they released the part # for the PCV like two weeks ago. BROCKS has it on his sight but zero availability. Anyone planning on using this until the flash comes out? I didn't see any tunes available either. So it would be a customer tune for almost every one sold.
Ya at this point you would have to goto a local tuner to dial in the fuel map. In that point it might be in your best interest to have a custom tune vs a OTS due to where you live. Florida maps will be different than New York maps. So buy 1 and find a local tuner.
Also don't forget, this only changes the fuel map in select throttle and load tables in the VE map. You can't change the ignition tables or low throttle position tables, fuel targets and a shitload of things unless you unlock the ecu or Motec it.
I'd just wait and skip it and wait for the unlocked ecu mod.
