Gen I and Gen II oil pans
gill_grissom
Will the Gen I oil pan fit the Gen II? I stripped the threads on my Gen II and I have access to a Gen I oil pan.. If anyone knows for sure just let me know.. Thanks in advance.. :please:
Why not use a helicoil or go back with the next size larger oil plug?
Better than helicoil.Difficult to find someone with a set.Suzuki uses it here officialy............
Sert - Wurth - YouTube[/url]
++ oil pan thread repair for stripped or leaking oil pan threads - YouTube[/url]
All I can tell you is that when I installed a Gen II pipe on my Gen I, there was a lot of clearance between the bottom of the oil pan and the pipe. It was a Yosh header and there's so much clearance that its very easy to remove the oil filter and take it out. I couldn't do that when I had a Yosh Gen I header on. I have heard that the oil pan on the GenII is deeper so this might confirm that. Hope helps a bit.
