RdRcr150
Installed built Gen I engine in Gen II frame. Stock wire harness. All electrics in good condition, all switches, relays, and all connectors required for running connected. Fully charged battery and all fuses good. Turn key on...nothing. Connect test light to turn signal relay ground and turn kill switch to off and dash lights illuminate with all digital numbers reading (. We have changed the cam position sensor to one from MPS. Grounds checked good. We have power to main switch and all connectors that should have power, do have power. Any ideas?
